www.silentrc.flyer.co.uk                                             Best viewed at 1024 x 768 resolution
Home
Non Electronic Bits
Over the years I have sourced various useful items not readily available through model shops.  If you are seeking something a little different, I may be able to help through my trade supplies and could already have small quantities in stock.
The following are some of the items I use myself on my Syncopator range of thermal soarers.
  • PTFE tubing for installing aerials and control cables - various sizes
  • Nylon screws, nuts and washers in M2 to M6 sizes
  • Steel screws, nuts and washers in M2.5 to M6 sizes, including Posidriv wing bolts
  • Tension springs for airbrakes
  • Disposable latex gloves for use  when working with epoxy resins
Wing Section Plots
I have a number of standard airfoil sections set up on my computer and can plot these at different scales for use as templates.
E-mail me your requirements and I will tell you if I can help.
